Cruiscontroll aftermount
Hi.
My b9 2009 has no cruisecontroll or speed limiter.
I have only the D marked normal speed pedal.
Do i need to switch this out to install the cruise control, and get this to work??
i will only activate the cruisecontroll in lexia.
Hi and welcome to the forum.
No, the D pedal works fine, the other pedal marked LV VD is only needed if you wish to use the speed limiter function.
You will need a clutch switch too, if not already fitted.
Thank you. Is the g type gass pedal compatible with the speed limiter??
I don't have the extra click when it's fully pressed
Attached Files Thumbnail(s)
Yep, G just means Gauche in French for left, so yours is left hand drive, D is for Droite (right) so it's fine with either one.
The extra switch on the LV VD pedal is just for the limiter function, and if the limit is set to say 50 but you need more for a safe overtaking manoeuvre, then pressing the pedal to the extra switch position just over rides the limit you had set.
If you buy a cruise control with a limit position, it will still be possible to enable cruise, but the limit position will do nothing and your maximum speed is unchanged.
Next gen Berlingo coming 2030
Last Post: shedpete
Today 08:36 AM
triangle light
14-06-2026 09:30 PM
13-06-2026 04:32 AM
Last Post: Jed Clampit
12-06-2026 10:44 PM
My Berlingo Multispaces
11-06-2026 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
