Threads: 2
Thanks Given: 2
Have owned my brand new Berlingo for less than a month and it has started to crunch when changing from 1st gear to 2nd gear when accelerating fairly quickly. I don't mean like Lewis Hamilton but when pulling out from junctions etc. It's fine if you change at low revs but it starts to labour. Obviously I'll return it to Citroen for investigation but was wondering if anybody has experienced the same, and are the gearboxes any good?
Threads: 3
Thanks Received: 3 in 3 posts
Thanks Given: 2
Just clocked up 14k. on my K9 van and no gearbox issues as yet, although I am quite gentle with gear changing and seeing as there must be a heap of counterbalanced linkage between stick and box, would think it would complain a bit if you were a little enthusiastic.
Even so, it shouldn't crunch, that sounds like clutch drag or synchro problems in the box.
Just my two euro's worth.
nick
Threads: 2
Thanks Given: 2
It does seem a bit odd. My previous PSA van (2015 peugeot partner) clocked up over 151k miles with no issues and was still on the original clutch when sold, so I know it's not my driving style.
I'll get it down the Citroen garage for investigation.
Threads: 19
Thanks Received: 31 in 30 posts
Thanks Given: 12
16
Sounds like the synchromesh being worn.
Now a 2019 K9 1.2 petrol.
Threads: 13
Thanks Given: 61
4
(05-12-2020, 09:40 AM)Mark604 Wrote: Sounds like the synchromesh being worn.
On a brand new vehicle that's only done 1000 miles?
Threads: 19
Thanks Given: 12
16
Certainly seems unlikely, what I'm saying is that's what it would sound like in an older vehicle, but if it is new, maybe there is a problem with the fit of the syncro. If it is linkage related it'd more often be happening on all or more than one of the gears, same as with clutch problems.
Threads: 0
Thanks Received: 2 in 2 posts
My 2019 xl with 14000 miles on it, occasionally wont go into 1st from neutral, have to bring up and reapply clutch then it goes in, citroen say nothing wrong with it.
