Threads: 3
Thanks Given: 1
Hi,
Does anyone knows what do I need to fit an oroginal fog lamp on my Berlingo. It doesn’t have fog lamp at the moment. Do I need any holder I think for the lamp itself?!
Thank for your help.
Threads: 75
Thanks Given: 223
164
You would need the lamp frame, lamps, trim surrounds and possibly the bumper from a model that has foglamps as standard (some don't have the removable panels to fit fogs at all) and then there is the correct stalk functions to switch on front fogs (comm2000 steering column controller) and perhaps DiagBox to code them as enabled.
You could fit the bumper (if your fog panels are not removable) and the lamps, frames and trims then wire them to a fused supply & switch somewhere if you don't care about using the original fog switches on the steering column.
