Threads: 4
Hello, so the bulb behind the temperature adjuster is blown. Does snybody know how to remove that part og the dashboard so I can replace the bulb? When you look at it, it doesnt seem to be any apparant way to remove it.
Threads: 8
Thanks Given: 305
36
There's videos on youtube showing how to do it.
Threads: 75
Thanks Received: 1,310 in 1,140 posts
Thanks Given: 223
164
The strip below the heating control panel can be prised out with a plastic tool like a stiff guitar pick or carefully with a small blade screwdriver and that exposes screws which hold the heater panel in place.
Threads: 20
Thanks Received: 7 in 7 posts
Here you go, I need to do this myself.
It's very well done and explained with tips.
https://www.youtube.com/watch?v=iJKvvFs37OE
Multispace B9 2009 1.6HDi
Thanks Given: 188
23
23-12-2020, 12:31 PM
(This post was last modified: 23-12-2020, 12:39 PM by Tomcat3.)
The video is a bit long but it explains it well but dont faff about tying to get the bulb holders out of the back of the panel just use a rubber glove for grip and pull the capless bulb out from its holder via the front so much easier. The capless bulb is a 286 12v 1.2
Are we there yet?????
Threads: 75
Thanks Given: 223
164
23-12-2020, 12:48 PM
(This post was last modified: 23-12-2020, 02:19 PM by Sol.)
Everyone is posting links to the M59 heater panel bulb replacement (except Cancunia), but this is the B9 section so I assumed the OP had a B9, it takes 5 minutes and a screwdriver to remove the B9 version.
thomasselboe can you confirm you do have a B9?
Threads: 20
(23-12-2020, 12:48 PM)Zion Wrote: Everyone is posting links to the M59 heater panel bulb replacement, but this is the B9 section so I assumed the OP had a B9, it takes 5 minutes and a screwdriver to remove the B9 version.
@thomasselboe can you confirm you do have a B9?
That's the only video I could find and the stuff looks exactly the same.
Could you give us a step by step please
Threads: 75
Thanks Given: 223
164
23-12-2020, 02:18 PM
(This post was last modified: 23-12-2020, 02:24 PM by Sol.)
Ok so the B9 has a removable heater controller, its only held in with a couple of screws which are hidden by a small plastic trim strip below the controller. Not the same as the M59 version which looks like a much bigger job. I think you also have to pull out the storage tray above it to make things easier, it just pops out.
Remove the trim strip in the pic below
Remove the controller, disconnect the plug and flip over
Bulbs are behind these caps:
Threads: 41
Thanks Given: 82
6
23-12-2020, 05:56 PM
(This post was last modified: 23-12-2020, 05:59 PM by Mike.)
