Threads: 2
Thanks Given: 8
05-01-2012, 08:46 AM
(This post was last modified: 05-01-2012, 08:48 AM by Yannis.)
Hello i have a Berlingo multispace 1.6 hdi 90ps.Does anyone know if i can install cruise control in my berlingo and if so to tell me how i can do that.thanks
Threads: 2
Thanks Given: 8
i dont know!!its 05/2009 model!
Threads: 25
Thanks Received: 235 in 131 posts
Thanks Given: 44
12
Mandatory to know, whether BSI of your car supports cruise control or not.
If supports you can install this handle.
Threads: 25
Thanks Given: 44
12
At first, this option must be "visible" in "New Car" configuration menu.
If this option is not supported by BSI, recommended SW update.
Second. If this option will not appear after SW update, BSI must be replaced on
class "B" or "C".
Except Lexia there's no any way to check anyth. on PSA cars, including Toyota, Fiat and MMC cars with Citroen logo.
Yes. I've heard something about VAG cars. Cars with a Multiplex wiring also supports output of some service info to the one of built-in LCDs.
The following 1 user says Thank You to pk7478 for this post:1 user says Thank You to pk7478 for this post
• Yannis
Thanks Received: 2 in 2 posts
Thanks Given: 3
So, find someone with Lexia and check your BSI. I bought stallk for cruise control at car trash for 10 €, mounted it at com2000 and enabled it with Lexia by myself. Simple and cheap, isn't it?
The following 1 user says Thank You to zlomjo for this post:1 user says Thank You to zlomjo for this post
• Yannis
Threads: 25
Thanks Given: 44
12
10-01-2012, 09:03 AM
(This post was last modified: 10-01-2012, 09:03 AM by pk7478.)
Zlomjo. For M59 models this works but not for all cars, especially with DV6 and DW8 engine.
The similar problem is for B9. Nobody knows what type of BSI, BSM, COM2000 was install in Vigo during production.
In most all cases, speed limiter will not work. Only CC.
The following 2 users say Thank You to pk7478 for this post:2 users say Thank You to pk7478 for this post
• ron, Yannis
Thanks Given: 3
Yes, you are absolutely right. On mine M59 with DW10 also doesn't work speed limiter. But fortunately this is the function that I don't care about it.
• Yannis
