  • 10 Vote(s) - 2.5 Average
front bumper removal to change headlights
how hard do you have to pull the side of the bumper to release it, a bit weary as it is colour coded.
Which vehicle?
On the M59 (Mk2), don't forget to release the clip through the slot inside the wheelarch, then it needs a sharp tug or two to release it. Better give it a couple of measured goes rather than one almighty heave and end up on your arse !!
Don't forget to say hello and tell us a bit about yourself, have a look here:-
http://www.berlingoforum.co.uk/showthread.php?tid=815
[-] The following 2 users say Thank You to Coco for this post:
  • cris, Dun Boatluggin
Thanks for that Coco , this is the first time I have used a forum ,as it is me that people ask about how to do this or that building, plumbing, decorating etc, also being 5 years on the gas conversion in the 70's I can usual take most things apart without instructions. I did look on the how to remove a Berlingo mk2 instructions, which is where I came across this forum. Sorry if there is some sort of etituette that I didn't follow. Will be sure to start with Hello next time.
I had removed one side before reading your advice,
Regards Chuck.
P.S. For future ref. for anyone else, the clips that hold the bumper req pushing down from above [with a stumpy srewdriver] then pull the bumper side away from the bodywork ,then forward.
[-] The following 4 users say Thank You to chuck for this post:
  • cris, dek2904, Dun Boatluggin, Sootyfoot
No problem.
Glad we were able to help and hope you enjoy the forum as much as we do.
(05-01-2012, 04:58 PM)chuck Wrote:  Thanks for that Coco ....
Regards Chuck.
Your P.S. is spot on. I have tried in the past to get that bumper off but was unable to figure out (even with some help here) how to release that clip. This morning I have replaced a smashed headlamp unit; because the unit was smashed away from it's fixing lugs and the headlamp came straight out, I was able to see clearly how the clip is released and it's just as you say. Annoyingly simple too!
[Image: bj4oj.jpg] [Image: 2u4jvvk.jpg]
[-] The following 2 users say Thank You to dek2904 for this post:
  • Dun Boatluggin, Grumpa51
Thanks for all the above - very useful as I wrestled with my front bumper.
I should like to add two things.
1. I found it helpful to slacken off the bolt holding the front wing on that is just inside the wheel arch (visible through the mud flap) and then I could get my screwdriver blade to depress the lug from the outside of the bumper (done carefully).
2. My number plate had been screwed on using overlong screws - these snagged when pulling the bumper off and also had to be released.
[-] The following 1 user says Thank You to Dun Boatluggin for this post:
  • Ol'Jeffers
Berlingo undertray
Today 04:46 PM
Today 08:32 AM
Today 08:16 AM
03-03-2026 06:17 PM
03-03-2026 05:08 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
Amdro boot jump for sale
Last Post: YTC1
28-02-2026 09:48 PM
Last Post: Muppets on Mars
27-02-2026 01:57 PM
