Berlingo L2 Heater Fault - Your help appreciated
Afternoon and Happy New Year
I have a Berlingo L2 van - It has a heater which is working on number 4 but nothing else.
I read somewhere that the cause of this is probably the heater resistor which I thought was located behind the glovebox - having taken apart the front of the van I am at a loss.
I have attached a photograph and perhaps if you know about Berlingos you could point me in the right direction before I ship it off to the garage.
Many thanks
Becky
Hi Becky, you're looking in the wrong place I'm afraid, it's above the pedals on the driver's side of a UK vehicle. I just did mine, see here for a guide with pics:
https://www.berlingoforum.com/thread-201...#pid127842
(02-01-2021, 01:34 PM)Zion Wrote:  Hi Becky, you're looking in the wrong place I'm afraid, it's above the pedals on the driver's side of a UK vehicle. I just did mine, see here for a guide with pics:
Oh that is truly amazing information, thank you so much for taking the time to reply
Ill put the van back together before moving to the drivers side !
Regards
Becky
I'm sure you'll fix it this time. You will need a very odd sized socket of 5.5mm and a few long 1/4 extension pieces with a knuckle joint adaptor. Halfords sell them, separately or in a small socket set.
Taking the accelerator pedal out first, makes the job a whole lot easier. Awkward still, but doable. Otherwise, you can't get the plug off, or back onto, the heater resistor.
The upper bolts on the accelerator pedal need the knuckle due to angle. All bolts are the same 5.5mm heads.
Next gen Berlingo coming 2030
Last Post: shedpete
Today 08:36 AM
triangle light
14-06-2026 09:30 PM
13-06-2026 04:32 AM
Last Post: Jed Clampit
12-06-2026 10:44 PM
My Berlingo Multispaces
11-06-2026 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
