Here is a possible cure for a recognised problem:
I have a 54 2.0 HDi, which had a slight judder at 50mph in 5th. Gradually this problem increased until it was a noticeable problem in 3rd (at c20mph) 4th (c30mph) as well as 5th. I asked for advice on the problem in the forum:
https://www.berlingoforum.com/thread-20273.html
I have a friend who has a Peugeot Partner which is mechanically identical and has the same symptoms. He sent me a link to a welding forum where this issue was discussed. Here are two of the comments:
"FIL has a Berlingo multispace... It's a 2litre HDI that has for a long time a judder that comes and goes when driving at low to medium revs, it's a known fault that is believed to be with IIRC the engine management system and nobody knows how to fix it." To which was replied:
"They don't like doing 30mph in 4th gear if that's what your judder is like but I just use 3rd up to about 50mph as it does about 50mpg everywhere anyway."
If you read the thread above youll see the problem was solved by replacing the MAF sensor. The car now drives very smoothly in all gears. If the engine is on a frosty start there is a perceptible judder at low revs but is non existent when the ngine heats up. So I don't think the problem is incurable, but rather that Belingo's/Partners are sensitive to less than perfect MAFs.
