  • 1 Vote(s) - 2 Average
[Transmission] Gearbox Engine Mount Bolt
Hi there,
Don't know if anyone can help I need a new bolt for the Gear Box Engine mount as during a moment of madness it occurred to me to cut it in half to get the gear box out the side. Probably shouldn't have done but it was tipping with rain. We have the clutch changed and the gearbox back in place but need a new bolt does anyone know the part number or have a spare one ?
Its a W reg (old W) Mk1 Berlingo
Thanks in advance.
John
Try putting your VIN number into http://www.catcar.info, change it to English, and go to the mechanical section > gearbox drawings, the bolts will be listed below with the part number on the left of the table.
Main dealer will be a good source for this
Ouch!
Expect that bolt to cost you an arm and a leg at the dealer. It's not a part that wears out, so it's not a common spare part. You should probably try a breakers' yard.
I'm not even certain why you cut the durn thing.
If you remove the mount bracket from the sidewall(10mm socket on an extension, and a bit of fiddling, or a mirror, and the bracket is off) then you can remove the bolt by loosening 3 or 4 bolts fastening a metal frame on top of the gearbox that the bolt is attached to.
[Image: Peugeot-Citroen-Various-Models-Capscrew-2-180333.jpg]
Wild guess but there's a part number to try. I think it's an M10, 150mm long on 1.5mm threading.
Our local Pug dealer is great for things like this (bit shut at the moment) but the two guys in parts will dig through their computers to pull out part numbers for weird stuff like the captive bolts in the front wishbones. Next day delivery they are £££££££ and then some. However if you are willing to wait a week or so then they'll get it added to their normal delivery from Peugeot HQ and than costs £.
ASDA AdBlue 10 January 2026
Yesterday 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
Blower fan
04-01-2026 09:58 AM
