Threads: 3
Thanks Given: 2
I had a berlingo driver 2019 had usb and aux in glovebox new 2020 model i received doesn't anyone know why?
Threads: 75
Thanks Given: 223
164
They're optional, not standard.
Thanks Received: 12 in 10 posts
my enterprise 2020 model as got them in Glove box
Threads: 75
Thanks Given: 223
164
The aux and usb are options that can be chosen when the vehicle is ordered new. They aren't a standard fitment across the range.
• Roxipoxi
Threads: 2
Thanks Received: 3 in 3 posts
Factory only inductive charging of the phone can be ordered later, everything else on order
The following 1 user says Thank You to xtimex for this post:1 user says Thank You to xtimex for this post
• Roxipoxi
Threads: 2
As they told me at the service station they can install it, of course it's not cheap - I already forgot how much they said it cost.
Threads: 7
Thanks Received: 22 in 22 posts
Thanks Given: 5
Not sure how much the induction plate is as an after sales fit but as the factory option which I had it was £100 extra on the cost of the build.
The induction plate works, but if you also use the phone on bluetooth while it is charging to play music to the sound system, the charging rate is quite slow.
2020 1.5 Blue HDi 130 Berlingo XTR
2009 1.5 Diesel Peugeot Partner
2007 1.5 Diesel Berlingo Desire
2003 Petrol Berlingo
