RADIO DISPLAY
Hi all ,I've looked for past posts on this but cant find any!! Any way,the radio display on the top of the dash,i noticed today that some of the little red bars on the digital display are not lighting up,theres about 7 or 8 kaput ,the radio is working fine but i dont know what station i am listening to !!can this be fixed or will i have to replace the display?? could someone explain either please thanks in advance,my mucker
Big Grin nice to be important,more important to be nice Wink
my ride is a  berlingo forte 1.9d 2003 model in pukey blue  Huh
It sounds like the display has failed easiest way to fix it is to get one of ebay, just look at the numbers on the back of yours and get one like it. It was common to loads of citroens and peugeots even different lcd colour displays to.
Ye thanks tomcat but how do i get it off ???
The cover over the central display just pulls up and backwards use a wide blade screwdriver or a trim tool to gently lever it up to start. Once off the display is held on by 2 torx screws and then unclip the wiring socket and its free.
https://www.youtube.com/watch?v=j4q-TDqK...jKulczycki
Easy life mate, pop the plastic, couple torx head screws, release the electrical connector clip.
Fantastic!! thank you scratchcat and you tomcat ,cheers ??
Ok ,I've taken it off the dash to get the number off the back !!cant find any matching numbers on ebay !! I put it back on and all lcd's are now working but very dim ?? is that still kaput ??
Have you checked the 3 bulbs in it they are easy to replace.
tomcat u r the man !! Yes two of the bulbs seem to have blown ,looking through my magnifier!! where do i get these ?? from the dealers ??
Thank you all for your help,much obliged to you !! i took the bulb to my local motor factors and bought 3 of them (£3.60) they are called capless bulbs !! I've learned something today !!all sorted once again thanks my muckers
Yesterday 06:15 PM
removing front strut
Yesterday 06:10 PM
Strut Top Mounts
Yesterday 05:47 PM
Rear seat belt breakage
Last Post: Mad one
12-09-2026 06:09 PM
12-09-2026 05:49 AM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
