[Engine] Fault codes
Hi,
Yesterday when approaching roundabout van just cut out, no pre warning or any signs when plugged in a while array of codes came up I have attached photo of codes as I have no idea where to begin!
2.0 HDI 2006
Attached Files Thumbnail(s)
Hi, can you let us know the vehicle model, engine and year.....hard to help with no details!
First thought anyway is the crank sensor is most likely for sudden cut out but details are always needed.
It's a 2.0 HDi.
I was also guessing the engine type until I spotted it at the top in the photo of the fault codes, but not everyone is Columbo  Big Grin
Deano,
If you put you vehicle details in your signature it will show up at the bottom of every post which is always a help. Wink
I'm with Zion on this, start at the crankshaft position sensor, remove it clean it and check that the plug / wiring to it is sound.
Clear the codes and see what happens, does it run, do the codes come back?
Some of the other codes may be there because the engine cut out.
Ah yeah I see the engine now in the screenshot.
Many thanks for the reply I will remove and clean sensor this week and check wiring, funny enough the sensor was replaced in october (5k miles ago) after cutting out before. I had a fault report sent off AA saying the sensor was knackered and needed changing which was done, wonder if there is more to it I.e wiring.
(16-01-2021, 02:57 PM)Deanoo2372010 Wrote:  Many thanks for the reply I will remove and clean sensor this week and check wiring, funny enough the sensor was replaced in october (5k miles ago) after cutting out before. I had a fault report sent off AA saying the sensor was knackered and needed changing which was done, wonder if there is more to it I.e wiring.
I had the same thing happen to mine and it was the crank sensor. I had only had it replaced couple of years before. RAC guy said many garages just replace with copies and you really need to have original part to ensure reliability. Obviously costs more he said but will save you money and trouble long term  Smile
Good point well made Betty. Pattern parts never work the way original ones do. Citroen spend £millions developing parts. eBay sellers don't.
(22-01-2021, 11:13 PM)Zion Wrote:  Good point well made Betty. Pattern parts never work the way original ones do. Citroen spend £millions developing parts. eBay sellers don't.
Thanks Zion Smile I am not a mechanic but I am learning from all the problems my van has thrown at me!  Idea
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
