Threads: 23
Thanks Received: 10 in 10 posts
Thanks Given: 1
I have been locked up for covid, went out to start the can and would not even turn over.
Went to connect the batter charger and the ground appears to be going to the live side of the bat!!????
I have a C-Tec mxs 7 charger but do i connect it.
Would appreciate a quick and easy answer nothing tech just where to hook up the + & -
Threads: 13
Thanks Given: 61
4
16-01-2021, 01:59 PM
(This post was last modified: 16-01-2021, 02:03 PM by Pedronicus.)
What gives you the idea that the ground is going to the live side? I also have a C-Tek MXS5 charger and if you connect it the wrong way round it will tell you by lighting up the '!' lamp when you plug it into the mains. The reverse polarity protection will ensure that the battery or the charger will not be damaged.
During lockdown I have given the XTR several 'maintenance charges'. I do not remove or disconnect the battery. I just open the car with the remote, open the bonnet and then re-lock with the remote. Wait 5 minutes before connecting the charger as @
manuk says, red +ve clip to the front terminal on the battery and black -ve clip to the stud on the inside of the r/h wing. The charger mains lead is then plugged into an extension lead (fed up from under the car into the engine compartment) from the house (RCH protected circuit) and charging starts. The bonnet is then lowered gently but not fully locked down. This lets me lift it every so often to check the indicator lights on the charger. When charging is complete (which can take a few hours) the mains is unplugged and the charger and extn lead removed. After a further 5 minutes I then open the car with the remote and shut the bonnet down firmly. Not had a problem with this method since the six charges I have given it since March last year.
The Ctek chargers can be left connected and fired up all the time and will keep the battery charged so no need to take the battery out for an overnight trickle charge.
Threads: 23
Thanks Given: 1
Well, called Greenflag as i i had breakdown cover (i forgot about that). Breakdown van arrived a couple of hours after i called, fast i thought.
He connected a batter checker ir what ever it's really called, and it showed the battery was kaput. One new battery later and all running ok.
What really threw me was that the positive lead off the battery was BLACK!!. He showed me the earthing knob to clamp to for the earth.
Only thing is that as i have a Kenwood radio/Satnav installed i can't change the time or date.
Threads: 13
Thanks Given: 61
4
Does the satnav not set it's own date and time from the satellite signals?
Threads: 23
Thanks Given: 1
Not sure if it shows the date but it does set the time from my phone connection i guess.
Threads: 75
Thanks Received: 1,306 in 1,140 posts
Thanks Given: 223
164
16-01-2021, 09:48 PM
(This post was last modified: 16-01-2021, 09:48 PM by Sol.)
Am I the only one who wonders what this thread is actually about? The positive terminal is at the front of the battery. The negative goes to the passenger wing bolt. The positive is marked with a big + symbol, not being funny, but it's hard to miss.
Threads: 8
Thanks Received: 504 in 452 posts
Thanks Given: 305
35
Are you psychic.
Threads: 75
Thanks Given: 223
164
Hmmmm I wonder sometimes...
• jj9
