Driver's Door Lock?
Hi guys
2006 Diesel 1.6L Manual 5 doors MULTSPACE DESIRE HDI (92) Estate M59
I recently acquired the Berlingo detailed above. As you can see, the key has been pretty much destroyed! works in all locks EXCEPT the driver's door - it inserts easy but shows no signs of turning! The lock may have been changed at some point and I don't have the proper key.
So, it seems my best option is to replace the barrel as, at present, I can't lock the car. Some little 'turd' has already stolen from it, luckily my RING cameras recorded him and I caught him 2 days later.
Can some one point me to the correct lock barrell so I don't end up buying the wrong one.
Many thanks
John
Eh, just take the one from the door on the opposite side...
There should be a plastic cover on the edge of the door. Remove that, and you should be able to remove the locking plate. Be careful not to lose anything inside the door, though...
(18-01-2021, 08:01 PM):)Gadgetman Wrote:  Eh, just take the one from the door on the opposite side...
Won't that just move the problem to the other side?
Thanks for the warning Smile
Yes, but if you have central locking that shouldn't matter...
Wink
(18-01-2021, 08:49 PM)Gadgetman Wrote:  Yes, but if you have central locking that shouldn't matter...
If it works!!
Thanks for the help.
Job done and it was easy Smile The only issue was the plastic cover was so tight and brittle it nearly got destroyed.
Thanks for all the help guys, I appreciate it.
I am Stitch-Up the original poster - I had to create a new account as I just couldn't login the other day!
Oil consumption at 200K miles
Today 02:32 PM
Forum activity
Today 06:32 AM
Emissions fault.
11-05-2025 06:29 AM
10-05-2025 05:31 PM
Winter Tyres
10-05-2025 02:42 PM
Start stop on van
Last Post: Rhino2k
09-05-2025 10:28 PM
09-05-2025 09:34 PM
Insurance Shocker !!!
Last Post: Keefus.
09-05-2025 01:45 PM
Part of Dipstick Stuck
Last Post: Nice4dad
09-05-2025 01:25 PM
BSI central locking again
Last Post: stuffe
09-05-2025 09:24 AM
» Replies: 23
