Changing the Torch Bulb to LEDs
After seeing the link to change the bulbs in the torch to LEDs I thought I'd give it a go as the illumination with the supplied bulbs is rubbish.
Shop didn't have the LED for the top of the torch, the one which operates with the switch.
Got LED for the part of the torch which operates when the boot is opened.
Didn't work at first due to polarity around the wrong way, reversed it and it works but it flashes like a strobe any ideas please ?
Multispace B9 2009 1.6HDi
I put a led in the top part of the torch but couldn't open the lens of the other part to put a led in there.
Link for the main led @ £3.94
https://www.ebay.co.uk/itm/LED-Light-Fla...2749.l2649
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
(20-01-2021, 07:59 AM)brodfather11 Wrote:  I put a led in the top part of the torch but couldn't open the lens of the other part to put a led in there.
just use a thin blade/screwdriver around the edge of the long plastic window and it just pops off.
Thanks for the eBay link but prefer to use a shop..
Got the lens off and fitted a led and no flashing , maybe your LED that's dodgy ?
Got a refund on the LEDs, they have no idea why it is flashing.
Whether the flashing LED has caused it but now my heater fan has stopped working on all speeds.
Is it a coincidence ?
Which years come with the boot torch? Not sure if mine should have one.
Sent from my HRY-LX1 using Tapatalk
(21-01-2021, 08:58 PM)Cooper Wrote:  Which years come with the boot torch? Not sure if mine should have one.
As in my sig, mine is 2009.
I have no idea about other years.
It was an optional extra, not a year thing as far as I know.
"Enterprise" vans have them.
(21-01-2021, 04:46 PM)magoo Wrote:  Got a refund on the LEDs, they have no idea why it is flashing.
Very unlikely. You've probably blown a fuse or the fan resistor has packed up in the dash.
(21-01-2021, 11:38 PM)Zion Wrote:  It was an optional extra, not a year thing as far as I know.
Not necessarily so.  Ours didn't. But there is the 'ciggy socket thingy' in the back offside.
Last Post: BigVtwin996
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
