Threads: 43
Thanks Received: 2 in 2 posts
Thanks Given: 28
Hi,
I have a 2002 berlingo that the Rear window won't demist properly, does anyone have any idea what the problem might be.
it demists the top and bottom of the window but not the middle part.
Threads: 8
Thanks Received: 507 in 455 posts
Thanks Given: 305
37
The heater elements in the middle part where it isn't demisting will be broken.
Threads: 8
Thanks Given: 305
37
The elements can be broken but not really that visible.
If you use a multimeter on each element you can trace where the break is.
There is conductive paint available that can repair the break.
Threads: 67
Thanks Given: 237
50
I never use my rear demister just use the air-con instead which works well.
Rear screen damp ... have you got a water ingress issue ???
Serieal Berlingo owner
Threads: 75
Thanks Given: 223
164
18-02-2021, 09:26 PM
(This post was last modified: 18-02-2021, 09:32 PM by Sol.)
Heated window tracks are always on the inside. Is this kit Chinese by any chance?
Mega tip so it doesn't look really shite, is use masking tape or frog tape, after cleaning the window with vinegar or alcohol, lay two strips of tape along the top and bottom edge of one track, laid carefully straight so as to create a sharp defined gap between them, the thickness of the track. Paint the gap with the conductive paint, then while the paint is still wet, carefully remove the tape. If you wait till it's dry, it can pull the repair back off the glass.
The following 2 users say Thank You to Sol for this post:2 users say Thank You to Sol for this post
• jj9, Squad
Threads: 8
Thanks Given: 305
37
The tracks are obviously on the inside, use the repair paint as Zion describes.
• Squad
