Sound insulation
Hi,
I am in the process of ordering a new berlingo van and have read that some models have better sound insulation. Does anyone know which models these are?
Graham
I lined all the inner panels in my van with 'dodo' sound deadening mats. I actually used a dB meter to measure noise levels at various speeds before and after and found that they had made a considerable difference. It's very noticeable! I will have to dig out the numbers but I think they reduced the noise by 5 or 6 dB.
I also did inside the front doors when I had the door cards off to do some wiring. I would like to do the roof on the cab eventually tio.
2015 Berlingo Enterprise 1.6 HDi
[-] The following 1 user says Thank You to Zen_Speedmaster for this post:
  • gtsmyth23@hotmail.com
Nothing in mine, but then mine was the first one privately on the road in the UK so the spec may have changed.
I have the full bulkhead in my van and noise isn't an issue whatsoever - i will say i do have the Driver so it is possible the cab is better sound deadened
[-] The following 1 user says Thank You to Tree for this post:
(26-01-2021, 08:35 AM)Tree Wrote:  Nothing in mine, but then mine was the first one privately on the road in the UK so the spec may have changed.
Yes i think the driver has acoustic windscreen
I am looking at the crew cab van with mesh bulkhead so will probably use sound deadening mats behind panels.
The did mats aren't crazy money and are easy to work with. The are lined with silver foil too and really help the light to bounce around inside the van.
Yesterday 08:36 AM
» Replies: 15
Last Post: Dyane6
02-11-2026 11:10 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
