DRL not working
Shocked
Hello guys.
i have purchased today 2016. Berlingo van,and have noticed that daylight running lights are not working,they are original yes.
Is there some trick how to turn them on,or only with diagnostics? Thank you experts Wink
They could have been disabled by someone with DiagBox software, if so then you would need to use that software again to re enable it. You can buy the kit on eBay or online but it needs some steps to install and use. Not so easy for a beginner but there may be someone in your area who has it.
  • Lateralus
I have. 2015 van and the DRLs can be enabled and disabled in the centre display menus. Failing that I did see that they can be disabled in diagbox too.
2015 Berlingo Enterprise 1.6 HDi
[-] The following 1 user says Thank You to Zen_Speedmaster for this post:
  • Lateralus
Hello guys,and thanks for reply. Do you have maybe some manual how to check in centre display,i do have handbook,but didn't notice inside nothing regarding those lights..
Just click the vehicle settings in the menu - there is for sure a way to turn them off otherwise they just work as side lights
Manual attached, see page 49.
If the sidelights or main lights are turned on, the DRL's are automatically deactivated. They can also be turned off using the configuration menu.
.pdf   AC-BERLINGO_II_VU_DAD_01_2012_GB.pdf (Size: 6.67 MB / Downloads: 47)
It is also possible to configure the DRLs to stay on with the sidelights in diagbox. I tried it but I didn't like it
For your issue though - and I am assuming you have an RD45 radio and orange centre display - check the vehicle configuration settings in the van itself first.
Also seems they are disabled from new for non Nordic countries in the BSI configuration.
I have audio system with bluetooth and orange display. And i have here on computer owner manual from 2016.,and it's different then yours,it doesn't say nothing about daytime lights.
(26-01-2021, 08:33 AM)Tree Wrote:  Just click the vehicle settings in the menu - there is for sure a way to turn them off otherwise they just work as side lights
I want them to turn on,now they are not working.
Post your Ghetto Fabrication / Modifications "Ph...
Last Post: Kokain
Yesterday 12:26 PM
» Replies: 38
Horn not working
Yesterday 12:04 PM
Berlingo digital cluster speedometer upgrade
Last Post: kaktusas
15-12-2025 02:48 PM
Cruise control retrofit
14-12-2025 09:37 PM
14-12-2025 01:33 PM
14-12-2025 12:49 PM
14-12-2025 12:00 PM
Anti Pollution fault warning
14-12-2025 11:39 AM
An almost Hydrolock in a DV6B
Last Post: chrisl
14-12-2025 09:36 AM
Last Post: chrisl
14-12-2025 09:27 AM
