Threads: 3
Thanks Given: 3
The seals on one of my injectors are leaking (blow by) is it an easy job or am I better off taking it to my local garage. Its is a 1.6hdi
Many thanks
Threads: 3
Thanks Received: 4 in 1 posts
Thanks Given: 6
Hi Jimbob1 I did one yesterday its fairly easy I did number 3 injector. Injectors can sometimes stick in tight other than that it took longer to clean all the black grime off and make sure you clean the flat seat where the washer mates.Try not to touch the tip of the injector or get any of the muck near it as the holes are tiny and easy to block..Best thing do is watch the you tube videos gives you a good idea and be patient getting the injector out if its tight (wd40) and rocket side to side carefully prying upwards with a pry bar carefully worked for me as not got injector puller good luck hope that helps.
Threads: 54
Thanks Given: 147
7
Possibly a typo here? "I would like to replace it with my girlfriend", what the injector?
Matt
previous
2016 1.6 HDi 100 XTR Grey Met
2010 1.6 HDi 105 XTR Gold Met
