water ingress boot
This is my first post so hope in the right place. Multispace 2014. Purchased June 2020.Plan to use as daily vehicle and camper at some point. I have recently discovered water under the boot carpet/foam. Have pulled the mat up which was soaking in particular round the edges and water pooled underneath. I have tried to mop it up and dry it out but in recent rain it has appeared again (have left the carpet folded back). No back seats in at the moment which has been useful and it appears dry where these would be. Noticed very wet under the rubber rear bumper seals inside which I think has made the spare wheel nut rusty. Any ideas?
Trying to now monitor how it is coming in by placing paper towels and then will sit in van in the next lot of rain which I'm sure will be coming soon! Not much fun.
Thank you
PS I'm practical but not mechanical!
Hi there Lorac
Try lookining for this thread "Any advice regarding boot carpets being wet!?"
I've put some coments their as I've had the same issue Sad
Get some low modulas silocon and seal round the tail gate bump stops to start with to test this I used a watering can to test
good luck Jake
Hi Jake
Thank you for pointing me to the thread will have a look. Where are the tailgate bump stops? Finding hard to visualise.
sliding door panel removal
Last Post: mojito
23-03-2025 07:35 PM
XL tyres
23-03-2025 06:57 PM
Last Post: deejay_xb
23-03-2025 10:06 AM
» Replies: 32
Unusual Braking Problem
23-03-2025 07:57 AM
Outer cv boot replacement
22-03-2025 10:13 PM
22-03-2025 10:02 PM
Diagnostic Plug
22-03-2025 09:55 PM
22-03-2025 09:52 PM
Rumbling Noise 55-65mph
22-03-2025 09:47 PM
Last Post: Beaumotor
21-03-2025 04:38 PM
