01-02-2021, 01:07 PM
Hi Guys I have a 2010 Citroen Berlingo 1.6hdi Van Occasionally I have a none start situation the engine cranks over but dose not start. I get out riddle the wires/plastic tray on the battery then it starts. It puts EML light on and i get P0192 fuel rail pressure sensor A circuit low.
I have removed the battery tray and battery cleaned all connections on and around the battery replaced the fuel filter my next step is to find the fuel rail pressure switch check the plug/wiring. I am not 100% but think it only started doing this after a new clutch was fitted and think something as been knocked or damaged.
Anyone any ideas had similar problem oh and know where the fuel rail pressure switch is it near the batter/fuel filter.
Any help appreciated thanks Monty.
