Flywheel/crankshaft lock hole; 1.6 petrol NFU; TU5JP4
Hi all,
Just in case someone is looking where the hole for locking the flywheel/crankshaft is and how it looks like. It is needed when changing the timing belt. The tool I am using is from Laser 6565. Originally the tool is 6mm, but I had to file it down to ~5.9-5.8mm or so, as rust and so on makes putting it inside pretty difficult.
This is for the 1.6 petrol NFU engine or TU5JP4
Last Post: magoo1
Yesterday 06:31 PM
» Replies: 74
Last Post: Dyane6
Yesterday 05:19 PM
1.6hdi starting problem
14-10-2026 01:38 PM
12-10-2026 02:50 PM
12-10-2026 02:31 PM
12-10-2026 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
