Hi, that one is not a 12v aux power socket, its the audio and USB socket inside that cover for the RD45 MP3 player version of the stereo, same as the one I have. You might get the tray from a scrap car, if you only want to fit a 12V socket there but the original is not one of that type, its an audio AUX input only.
I'm not sure if you can add them if you don't have the RD45 stereo, maybe better from a used car in a scrap yard. Or from ebay? I don't know the part numbers of these parts, sorry.
The following 1 user says Thank You to Sol for this post:1 user says Thank You to Sol for this post • deejay_xb
Ok, grab that one I posted off eBay and change it over, your stereo should have the usb socket on the rear to connect it to.
I think it pulls out, pry the strip off between that and the heater controls and there are two torx screws under there, I think they hold the tray in as well as the heating control panel. With this screws out, the tray should pull out.
