Threads: 11
Thanks Received: 4 in 3 posts
Thanks Given: 1
Hi, I have tyre wear on the outside of the rear tyre's om my 2019 Berlingo 1.5 HDI, is there tracking adjustment on the rear?
In general the tyre wear is quite disappointing with 3-4mm left at 12000 miles I would have expected better from Michelin's.
Thanks,
Ronnie.
Threads: 75
Thanks Given: 223
164
It's not adjustable I believe, and is a known issue caused by the rear geometry. There may be fixes but they involve shimming components of the rear sub frame. It's been discussed many times here. No adjustment is available though as standard.
Could be due to running lightly loaded as the camber is set to deflect to straight when carrying a load, wears on the outsides when not loaded etc. Can't remember the exact reason. Lots have it though. It's not the Michelins - they wear all tyres out on the rear at the edges.
Threads: 20
Thanks Given: 7
15
Strange as i replaced my originals at 50k - outside did wear but got to a point and stopped
Threads: 75
Thanks Given: 223
164
03-02-2021, 12:54 PM
(This post was last modified: 03-02-2021, 12:55 PM by Sol.)
Yeah I've had my rear ones on for a year but then, have only covered 3k miles in the year as I work 5 miles from home, plus have spent a lot of time working from home during the lockdowns etc (50% at least) but I see no wear on them at all.
We did have a big thread on here that Mark Lightfoot responded to (PSA Independent specialist) who said it was a known issue and he has "fixed" the problem in the past but that there is no actual adjustment to be had. I think he shims the subframe mounts or something.
Threads: 11
Thanks Given: 1
I turned the tyres on the wheels to get a bit more out of them but without doing this they wouldn't have lasted 15000 miles.
Threads: 18
Thanks Received: 8 in 7 posts
18-06-2021, 03:42 PM
(This post was last modified: 18-06-2021, 03:42 PM by ComboLifer.)
It’s a known issue and I have found the factory fitted Michelin’s while being excellent tyres for grip do suffer more than other brands (uniroyal and Avon) for outside wear on a Berlingo
Both uniroyal and Avon gave considerably more mileage (33k and 29k) despite eventually suffering from the same outside tyre wear compared with the factory fit Michelin’s (18k).
Threads: 18
Had my tyres checked this week
1.2 Rifter XL 7 seater with 18,000 miles on factory Michelins
Fronts - average 4.5mm
Rears - average 5.5mm
Still plenty of life left in them
Threads: 41
Thanks Given: 129
9
I've kept checking my K9's rear tyres to see if they were under-inflated, and I've also been wondering if a pothole had knocked out the alignment, so it's useful to know that this uneven wear is a known issue. Have done 21,000 miles and the Michelin on the nearside rear looks OK in the middle but has really worn down on the outside edge. The van is usually moderately loaded. Might try Hankooks as a replacement and see if they fare better.
