Threads: 8
Thanks Received: 507 in 455 posts
Thanks Given: 305
37
In that location a MIG welding repair should be no real problem and the windscreen shouldn't be a problem.
With most welding repairs the rot isn't always limited to what you can see, you often have to cut back a lot further to find good sound metal.
I would guess to have rot in that area there has been standing water, so there could be rot inside the scuttle so make sure to have a good look in there.
Check that no water has found its way into the cab, check that the carpets are dry.
• Lanky94
Threads: 5
Thanks Given: 4
21
Difficult to see if that's surface rust or whether there are any holes. Surface rust can just be cleaned up & Kurust. If using an angle grinder/welder near the screen make sure the glass is covered with a damp towel - an angle grinder will put little bits of carbide into the glass, as will spatter from a welder. Disconnect battery and even disconnect/remove ECUs to make sure no 'electrical' harm comes from the welder. Also make sure that there's no fuel line or soundproofing to set fire to and keep a fire extinguisher handy.
Apart from all that, it's a couple of hour's work!
The following 1 user says Thank You to oilyrag for this post:1 user says Thank You to oilyrag for this post
• Lanky94
Threads: 39
Thanks Given: 1
4
I would be taking the wipers and plastic grill off to look at the otherside but I would have thought it was a fairlyeasy repair, with the bonnet off and the winscreen covered up.
Tha hardest job will be removing any flamable material from the vicinity including up under the scuttle in the cab.
Knowing the price of Romahomes (we have an Outlook) it has got to be workth repairing.
Not a common area for rust on a Berlingo but C15s had rusted scuttles, when we had a C15 Romahome I had to rebuild the scuttle and the area round the bottom corner of the windscreen.
Peter
Threads: 29
Thanks Given: 67
20
It looks easy enough to weld, slap some wet newspaper on the screen and cut the rusty section out, disconnect the battery and crack on. I did a similar job on an old Corsa my daughter had, didn't bother removing the bonnet just wedged it up as high as it would go with some 2x1
Threads: 15
Thanks Received: 102 in 92 posts
Thanks Given: 15
6
On the Romahome backend there's a bit of 'extra chassis' added (sorry not sure what the posh name is) - this extends the normal steelwork to give you the back door and surrounding area.
Have a good look around the join area and forwards to around the middle of the rear wheel arches - the added section can sometimes cause a deformation/crack - my pet theory being folks dumping a 50 litre Aquaroll or the like inside the back door and then driving over cobbles for hours applies an extra force on the joint section.
Threads: 39
Thanks Given: 1
4
Graeme that is only on the R25. You can buy the chassis Extension from Noth Star on the Isle of Wight
The C15s and the Berlingo based Duo, Outlook and R20 just use the standard Citroen platform cab nvestmenwith no extra steelwork at the back. we have had a C15 and have owned our current Outlook from new in 2007. It is the best investment that we have made.
Peter
Threads: 15
Thanks Given: 15
6
Ahhh - my bad then Peter apologies.
Threads: 25
Thanks Received: 27 in 26 posts
Thanks Given: 16
6
I would just add that I would cover the engine as well, I have an old fire blanket that I use.
