[Warning Light] Additive Pump
Hi
I have a Berlingo Enterprise 75 Blue HDI Van (2016).
I have the dreaded Triangle warning light and Engine Fault warning. Diagbox shows no communication with Multiplex additive pump. The pump and tank (full) was replaced a few months ago. I presume the ECU isn't picking up a signal from the pump. A friend of mine has the same model and year Berlingo so we placed his tank / pump on my van but the problem was not resolved. My next thought is the cable to the pump which apparently has a habit of failing but i can only get to about 6 inches of it before it disappears behind the top of the fuel tank. Does anyone know where it goes from there?? Also is it possible that the lack of communication / CAN fault is just a reset issue on the ECU or BSI.
Your help and advice would be very much appreciated.
Hi,
Is this an AdBlue pump or an Eolis pump? Which tank was replaced?
(03-02-2021, 07:52 PM)Buki Wrote:  Hi,
Hi Thanks for your reply. i'm referring to the Eolys tank.
Check the fuses, here is the diagram:
https://fuse-box.info/peugeot/peugeot-pa...2018-fuses
Pug is the same as the Citroen. A blown fuse can cause no comms.
Today 11:13 AM
Today 09:14 AM
Last Post: JPCoetzee
Yesterday 10:34 AM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
