[Engine] 2.0 HDi Timing Belt Change
It's been a while since I sold my 2.0 Berlingo, but I now have a (ahem) Peugeot Expert 2.0 HDi that's only done about 50k miles but is coming up to 10 years old so thought I'd see about changing the timing belt. It's a slightly different engine, but am hoping there are enough similarities to glean some wisdom from those that have done theirs here.
I seem to remember stories about problems with the floating sprocket on the crankshaft. Has anyone got any tips about what to look out for?
How do I get the crankshaft bolt undone, is it practical to turn the engine on the key with a socket & breaker bar against the ground?
Thanks in advance.
(04-02-2021, 07:41 PM)cancunia Wrote:  How do I get the crankshaft bolt undone, is it practical to turn the engine on the key with a socket & breaker bar against the ground?
 .... No ... !!!! Lock the flywheel properly  !! ....................... and for tightening !
(04-02-2021, 07:41 PM)cancunia Wrote:  It's been a while since I sold my 2.0 Berlingo, but I now have a (ahem) Peugeot Expert 2.0 HDi that's only done about 50k miles but is coming up to 10 years old so thought I'd see about changing the timing belt. It's a slightly different engine, but am hoping there are enough similarities to glean some wisdom from those that have done theirs here.
Quote:I seem to remember stories about problems with the floating sprocket on the crankshaft. Has anyone got any tips about what to look out for?
lock all pulleys except crank, lock flywheel. leave all play of the belt on tensioner side and tighten crank bolt after tensioner.
Quote:How do I get the crankshaft bolt undone, is it practical to turn the engine on the key with a socket & breaker bar against the ground?
Lock the flywheel. undo the bolt. Don´t use impact wrench.
Thanks for the replies so far. Much appreciated.
I found an older thread with some helpful info..
Geoff, do you still have these images somewhere? They're not on Photobucket any more.
https://www.berlingoforum.com/thread-101...l#pid64209
        ^^^ Post now updated
Attached Files Thumbnail(s)
  • cancunia
(06-02-2021, 04:30 PM)geoff Wrote:  ^^^ Post now updated
Thanks.
Double sided so that it can be used from both directions for undoing / doing up?
Sorry human error ... oops ! ..... I filed the wrong side by mistake ... lol
10-11-2026 08:36 AM
» Replies: 15
Last Post: Dyane6
02-11-2026 11:10 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
