Threads: 5
Thanks Given: 3
Hi,
I'm looking to retrofit cruise control (not including the speed limiter as well) to my 2014 XTR Berlingo and need the help of someone with the software to "switch it on" via diagnostics.
Does anyone know of a local Citroen specialist in the Sussex area who could help with this? Probably won't approach a main dealer as I've read some bad reports about that route.
thanks
Threads: 123
Thanks Given: 250
34
If you look on the French Car Forum, they have a list of members with Diagbox, the Peugeot forum also does IIRC. Failing that, you need to look for an Indie in your area.
The following 1 user says Thank You to cancunia for this post:1 user says Thank You to cancunia for this post
• jazzyp
Threads: 7
Thanks Received: 26 in 24 posts
i got it but am in Bournemouth
I went to main dealer originally to get a price to have it done and they point blank refused to fit even the genuine 1 that they supply with disclaimers to sign . I think the hardest bit was cutting the plastic cover from what i remember
The following 1 user says Thank You to Oi69 for this post:1 user says Thank You to Oi69 for this post
• jazzyp
Threads: 18
Thanks Received: 11 in 6 posts
Thanks Given: 16
4
I did a retro fit cruise control last year and wrote detailed instructions. Here is a link and I hope it helps.
https://www.berlingoforum.com/thread-19522.html
My Car :- 2010 Citroen Berlingo XTR Multispace
