Threads: 6
Thanks Received: 4 in 3 posts
Thanks Given: 6
I'm getting the overheating warning light and "STOP" light flashing from start up. It's obviously not overheating and the lights go out after a mile or so. I have had overheating problems in the past but sorted now so I'd like to be sure the system is working as it should.
Any suggestions for cause and cure.
(Mine is 2003 Multispace 2l TDI)
Threads: 75
Thanks Given: 223
164
08-02-2021, 10:50 PM
(This post was last modified: 08-02-2021, 10:53 PM by Sol.)
When you say you sorted overheating problems, what did you do?
(Hopefully not RadWeld etc)
A bit of background might help us to follow the trail.
Threads: 67
Thanks Given: 237
50
Can I assume the coolant level is correct ?
Serieal Berlingo owner
Threads: 75
Thanks Given: 223
164
09-02-2021, 06:47 PM
(This post was last modified: 09-02-2021, 06:49 PM by Sol.)
Might just be a bad sensor or damaged wires from when the head was off. If you get a Bluetooth OBD reader and the torque pro app, you can pair it to the phone and read live data from the coolant sensor..that would confirm if it actually is going over 90 etc. Bluetooth OBD plug is about £20, I've got a vgate one (orange model) and it supports all PSA protocols. As does the Carista one (even though their app doesn't work on PSA cars) and I can read every sensor in the car live. It also reads and clears fault codes. Torque pro is about £2.50 off the app store.
• crossvale
