Threads: 2
Thanks Given: 3
Good Afternoon All
Can i please ask what are the widest tyres i can put on a 2003 berlingo,
also because im new to these cars can someone tell me what mk mine is, its a 2003 2.0l hdi
Thanks For The Help
Threads: 32
Thanks Given: 24
Hello & welcome,
Firstly your is a Mk2 - known as a M59.
Tyre sizes recommended are either 175/70 14 or 185/65 15
The following 1 user says Thank You to Coco for this post:1 user says Thank You to Coco for this post
• Holm200277
Threads: 147
Thanks Given: 263
11
Welcome, Coco answered your questions. If you are keeping the original steel wheels then the 175 tyres are recommended.
Threads: 32
Thanks Given: 13
09-01-2012, 05:29 PM
(This post was last modified: 09-01-2012, 05:29 PM by tucker.)
I would imagine on the HDI it has the 6 inch wide x 15 inch steel wheels which came with 185/65/15.
If so you could fit 195 tyres on those rims, which is what I currently have fitted in winter tyres.
Any wider and it may catch the bodywork. You would certainly struggle unless the profile was smaller as my 195/65/15's leave very little room on the fronts when the wheel is turned full lock.
The following 1 user says Thank You to tucker for this post:1 user says Thank You to tucker for this post
• Holm200277
