Correct wheel bearing?
    Hi all, I’ve got my mechanic coming out to do front wheel bearing. I just want to check I’ve bought the right thing. 2009 M59.
These are what I’ve got. These look right to you?
Thanking you!
My little beauty...2009 M59 Peugeot Partner 1.6hdi (90bhp)
Well it looks like a wheel bearing, circlip and driveshaft nut to me, you worry too much.
  • jj9
Big Grin
Thanks Geoff, yes I realise it’s a wheel bearing kit... because... well I bought it Big Grin  My question was whether it’s the correct bearing for my model.
But thanks for your reply
Citroen - Catcar.info
This site will tell you part numbers etc.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
  • LukeClark
Do you have ABS? The bearings are the triggers on the B9, not sure if the M59 used the same system or the reluctor ring version. I did the brakes and discs when I had one of those but never had to do any ABS stuff on it.
Point being, if it does use a magnetic coded bearing then your ABS will fault and won't be recoverable till the right bearing is fitted again.
Just a heads up. Could be you don't have ABS or it uses reluctor rings instead so not an issue. (Unless the mechanic breaks it doing the bearing)
  • LukeClark
(10-02-2021, 12:09 PM)LukeClark Wrote:  Thanks Geoff, yes I realise it’s a wheel bearing kit... because... well I bought it Big Grin  My question was whether it’s the correct bearing for my model.
It looks to be but whether it is or not can't be ascertained by looking at a picture of a wheel bearing.  Rolleyes
(10-02-2021, 02:13 PM)Zion Wrote:  Do you have ABS? The bearings are the triggers on the B9, not sure if the M59 used the same system or the reluctor ring version. ....
The M59 uses the reluctor ring system so has a standard bearing. (same bearing with or without ABS)
[-] The following 2 users say Thank You to jj9 for this post:
  • LukeClark, Sol
[/quote]
[quote='Zion' pid='131089' dateline='1612966388']
My point exactly - no part number = no idea
Anyway how did you get on ???
Thanks Zion for your help.
Does your mechanic have a welding set with him?
Chances are that the bearing will be rusted in place & the best way to get it out will be by running a bead of weld around the inside of the bearing shell. There are for sure other ways of getting the bearing out, but for me, taking it to the local garage was the way to go. One of the best Tenners I've spent.
(10-02-2021, 06:10 PM)cancunia Wrote:  Does your mechanic have a welding set with him?
 I'm lucky to own a hydraulic press so used a short piece of heavy hex bar to bridge the outer race and 3 tons of pressure later it was out. Without some means like this it's going to be very difficult to remove without causing some further damage. Good luck!
Eolys replacement tank
Last Post: Harrythephot
Yesterday 12:02 PM
Yesterday 10:27 AM
Ahh bless them...
12-08-2026 04:54 PM
12-08-2026 04:45 PM
Last Post: stu76
12-08-2026 05:41 AM
Last Post: BigVtwin996
09-08-2026 12:10 PM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
