10-02-2021, 07:29 PM
Hi all,
My inner tie rod needs replacing and I thought that is easy enough (M59; 2007). Is there any trick with the big Neilsen/Laser tools (photo attached) to make them work. I screwed the new inner tie rod in, slid the tool over, but it just spins and does want to grab at all. Surfaces are clean (brake fluid), but it just spins. The tool is for 35-45mm ball joints, so it should work.
Is there any trick to this thing or it's somewhat broken. I can see how it operates, friction on the sides, but it does not want to do that on the tie rod ball joint. If I push it with hands, it does start to grip, but not on the tie rod. I resorted at the end using this cheap clamp-type thing (photo attached) which worked with the 80Nm torque, but with too many extensions and with the type of clamp I am not entirely sure if the 80Nm with the torque wrench are achieved. I have threadlocker on it (Liqui Molly green stuff; high strength), but still would have liked to use the direct on the ball joint tool.
Many thanks for any help with this.
Neilsen tie rod tool
Cheap over clamp type tool
