Back door n/s water leak
Hi from new user with first post about my first 2013 LWB belingo van not a work van just for my hobby,
bought my van in December and opened back door and noticed it was half full or water, I noticed number plate light clips were snapped off
and siliconed in so installed new ones and still leaked bought some 2mm rubber off Amazon cut fitted those with a bit of silicone and now no leaks.
but noticed a leak around the door handle even though they appear to have there gaskets. Any ideas from you the experts.
Check round the thick door body between the thinner outer skin, and the inner pressed panel, around the thick part they often have holes covered with a kind of sticker. I found one has come off of my side door on the van so I cut out a bit of t-rex tape (waterproof duck tape) and stick it over the hole snugly to stop water getting in.
Thanks for that when I done a water test water seemed to come through the middle and run along the length then run down into the door.
Yesterday 05:21 PM
Yesterday 05:12 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
