Threads: 147
Thanks Given: 263
11
Welcome, glad you are pleased :thumbsup: .
Will probably be a bit of trial and error really. Is it harder to start from cold, in cold weather? Is it hard to start at all? Do you have to keep the revs higher to stop it cutting out when its juddering? What sort of mpg are you getting?
The sluggishness could be down to your fuel filter, could be one of your injectors, could be the egr solenoid (if it is in limp mode). Any warning lights?
Threads: 50
Thanks Given: 743
10-01-2012, 10:35 PM
(This post was last modified: 10-01-2012, 10:36 PM by Ol'Jeffers.)
Try avoiding the cheapest diesel. Fill up with Shell or BP next time or
add some Millers diesel treatment (which I use all the time) and it does what it says on the tin. I find that it pays for itself. :thumbsup:
Threads: 17
Thanks Received: 117 in 92 posts
Thanks Given: 153
10-01-2012, 10:39 PM
(This post was last modified: 10-01-2012, 10:45 PM by adam3rdcanvey.)
Sounds like cold start cable incorrectly adjusted?
What mk of berlingo have you got?
Threads: 3
Thanks Given: 1
Right! Thanks for you replies much appreciated. What does it look like and where is the cold start cable and how is it adjusted! Sorry I'm not very mechanically minded! Getting fuel filter done at wkend and going to buy better diesel. Will let you know how I get on. Thanks : )
Threads: 5
Thanks Given: 6
Hello Widjet - I was searching to find similar issues to mine and your post here seemed to match perfectly. The Bingo runs well but is a bit stuttery especially at the start of a journey - problem isn't noticeable on motorways and doesn't have issues starting or stalling. No smoke or warning lights.
I have also gone down the theory of the fuel - (once I established glow plugs don't work like spark plugs) The fuel currently in the tank was bought in France some weeks ago where I know the BIO content is high. I had the fuel filter replaced last year so doubt it could be that.
Yesterday I filled her up but put 500ml diesel additive into the tank, hopefully I will see an improvement.
Did you get to the bottom of your issue?
How many people use deisel additives? Millers seems to get some positive feedback.
Threads: 3
Thanks Given: 1
Hi no I never got to the bottom of it! But have been driving her six months and I don't really notice it anymore. Tried all sorts including fuel relay?, starter motor etc and none made any difference. Sorry I know that doesn't help but if you ever find the cause let me know!!
