Threads: 11
Thanks Given: 2
Recently when I start my van there’s a loud beeping noise, if I turn the head unit off and back on it’s gone but I’m just concerned to what it actually is? I’m sure I saw a battery light flash once but I can’t be 100% certain. It starts and drives fine. I haven’t been driving it much recently due to covid and not working not sure if that has anything to do with it? Thank you.
Thanks Received: 1 in 1 posts
Thanks Given: 1
I have same problem. Did you fix it?
Threads: 13
Thanks Received: 139 in 113 posts
Thanks Given: 162
18
Hi,
Check your battery with load tester or battery tester.
If it is going bad it will beep every time you start engine and it will not display any error.. wtf.. nice going citroen.
Best regards,
brajomobil
Threads: 75
Thanks Given: 223
164
Brakes....
