16-02-2021, 07:17 PM
Hi!
This is my first thread as I just got my first Berlingo.
So there are few problems.
First of all, I have 2004 petrol 1.4i engine.
I have no problem with idling, but while driving when press clutch or put in neutral engine just stops, I can put back in gear or turn key and it will start with no problem, sometimes it will start by itself.
OBD gives me these two codes:
P0412
Secondary Air Injection System Switching Valve A Circuit Malfunction
P0420
Catalyst System Efficiency Below Threshold (Bank 1)
Bosch ME746 - Front pre-catalyser. Ageing. (Front bank on PSA V6)
MM48P - Catalytic converter ageing.
EDC16C3/34 - Particle filter. PEF overloaded.
Another problem is with faulty speedometer/odometer.
THEY DONT WORK!
I replaced sensor on gearbox and nothing changed.
I can trigger speedo with obd software.
Then I wanted to to check wires, I found pin 1 and it was ok, also pin 2 had grounded, but I can't find where pin3 goes. In other threads there was some wiring diagram, but it didn't work for me, because there wasn't any wire in 48V MR pin B3.
Thanks' in advance!
P0412
P0420
THEY DONT WORK!
Thanks' in advance!
