Threads: 2
Thanks Given: 1
20-02-2021, 07:11 PM
(This post was last modified: 20-02-2021, 10:34 PM by superbees1.)
Hi thanks for letting me join i have a 2004 1.9d berlingo van
help needed sometimes i try to start van sounds rubbish and wont rev so undrivable so leave it 10 mins then it is fine so far new glow plugs battery cleaned egr new inlet manifold seals full service drained fuel flushed through but still giving me grief and advise greatly appericated videos
Threads: 75
Thanks Given: 223
164
Is this from stone cold?
Have you checked the waxstat advance unit on the rotary injection pump if it's cold starts that are an issue. They stick and fail to advance the pump / raise the idle for cold start. Makes it splutter and hunt, won't rev easily. Once warm, they're fine.
The wax stat cable (runs from the thermostat to the pump) it should be taut when cold, and slack when hot. If it's slack when cold try holding the lever it pulls on on the pump (the cold start / fast idle lever) when starting (a piece of wire will do - the engine will run fine with the lever in this position)
I jammed it at a good spot on my first 1.9D van and it worked fine for ages till I swapped it out.
Threads: 2
Thanks Given: 1
21-02-2021, 09:52 AM
(This post was last modified: 21-02-2021, 09:53 AM by superbees1.)
thanks for reply wouldnt start at all this morning so i put a screwdriver blade in between the lever and fired up straight away and when i got to my destination i checked cable and hadnt got slack so will give this a try cheers
Threads: 75
Thanks Given: 223
164
No worries. It likely will be the issue then.
Threads: 75
Thanks Given: 223
164
21-02-2021, 11:15 AM
(This post was last modified: 21-02-2021, 11:28 AM by Sol.)
Yeah that looks right from memory.
It's 10 years since I had that model / engine. But it's front left as you look at the engine, near the slam panel.
See here, if this is correct the stat is item 7, follow the cable and the end of it is where the lever is:
https://www.ilcats.ru/peugeot/?function=...anguage=en
• superbees1
Threads: 2
Thanks Given: 1
Looks like it wasnt that wouldnt start at all this morning messed with the valve in diffrent positions but wont fire up also stink coming from exhaust
normally when like this i leave it for 15 mins then it fires up
Threads: 75
Thanks Given: 223
164
22-02-2021, 06:03 PM
(This post was last modified: 22-02-2021, 06:04 PM by Sol.)
Maybe the glow plugs are duff then, the 1.9D needs them all the time to start. No matter the temperature. Stinky exhaust will be unburned fuel. Tried a double heat before cranking?
Using a 12v lamp with wires connected, you can go from the GP rail to earth and will know when they are actually on (or supposed to be) - if it never lights up with ignition just turned on, then you might have a blown fuse or bad GP relay. If it lights up but doesn't want to fire up straight away, could be the plugs are shot. They don't last forever.
Thanks Given: 188
23
Out of interest how many miles has the van done?
Are we there yet?????
