Threads: 22
Thanks Received: 12 in 10 posts
Thanks Given: 2
Hi
Cancunia replied to my earlier post - suggesting a new thread, if anyone has any further advice please:
I'm fairly sure that JJ9 & others have some views on how best to check & tighten, maybe post a new thread on the subject of how best to tighten them?
I sold my 1.6 a couple of years ago, so from memory..
Remove the engine cover
Undo the injector wiring guide, it's black plastic held in place with a couple of 8mm a/f head bolts.
Get a 7mm hex allen key & check that the injector clamps are not loose by applying a light loosening & tightening motion. I did this by feel and tightened the loose ones so they were no tighter than the tight ones (hope that makes sense).
There are 2 bolts per injector, they look like sleeve nuts and the 7mm allen key will only fit them.
Threads: 67
Thanks Given: 237
50
22-02-2021, 04:30 PM
(This post was last modified: 22-02-2021, 04:31 PM by geoff.)
Go carefully and gently is the watchword or you'll break something.
When I did mine I ground down the end of the allen key to mimic a ball end key and further up the shaft I ground to a round form / reduced diameter the shank of the key so that access to No4 cylinder injector is greatly improved, that way you reduce the degree of dismantling the fuel system.
Worked for me.
As sai though go gently !
Serieal Berlingo owner
Threads: 8
Thanks Given: 305
36
I'm pretty sure it wasn't me that advised how to check / tighten the clamps as I've never had to do it, but no problem
Reading up on the subject there seems to be a few different opinions as to the best way to retighten them.
I think geoffs method is as good as any, and I think I would just tighten them by feel, but if you want a few more ideas have a read....
Here
And Here
Hope this helps.
The following 2 users say Thank You to jj9 for this post:2 users say Thank You to jj9 for this post
• cancunia, saskak
Threads: 123
Thanks Given: 250
34
23-02-2021, 09:21 AM
(This post was last modified: 23-02-2021, 09:27 AM by cancunia.)
And there was me thinking the Multijet was a Fiat engine!
There's a lot of crossover between Torx & hex fittings, for example the Torx heads on the bolts will probably fit a small hex socket very well, as do 2 guide studs on the sump & the larger bolts on the suspension mounts. Personally, I prefer to use like for like where possible, but don't have any Torx sockets which is where I discovered the above.
Threads: 75
Thanks Given: 223
164
24-02-2021, 07:34 AM
(This post was last modified: 24-02-2021, 07:35 AM by Sol.)
I always use the one for the job, I got torx, spline, Alan and Mercedes star ones (wave stars, can't remember the name) as I've used torx on Alan and vice versa when stuck but it's not ideal if force is required. Luckily on the injectors you don't need much force but if you did, better to get the right thing.
Halfords sell all socket and bit types in singles so that's one way to get them. I bought deep impact sockets one by one that way, only as I needed them, for a few quid each.
