Thermostat housing vent
When I changed the thermostat housing on my van (twice...), the vent/bleed fitting was very tight to push into the new housing, despite lubricating the O-ring with Vasaline. I ended up distorting the threaded part and now I find it's weeping coolant. Searching online doesn't seem to come up with anything, does anyone know if they are available or will I have to buy a S/H housing to get one?
My van: 2008 Berlingo 1.6 HDi Enterprise - a bit ratty!
I had something similar, the bleeding screw valve was leaking a bit and loosing coolant. I think I had it disturbed and somehow twisted from the actual body, not the valve. I had to take it apart and put again and it sealed (https://www.youtube.com/watch?v=Qa-92Xlon5g).
If the thread is damaged and not sealing, there is not much you can do, but replace it with a new one. The PSA part number is: 1323V3
Maybe try some plumber's PTFE tape?
I did think of PTFE tape, I would like to replace it possible as the 'U' shape clip is broken as well and I put a cable tie round it. I can't understand why the hew housings come with the fan switch but not the bleed fitting... maybe the more expensive ones do?
Strut Top Mounts
Today 07:58 PM
Yesterday 09:30 PM
Yesterday 09:27 PM
Rear seat belt breakage
Yesterday 04:13 PM
removing front strut
13-09-2026 06:10 PM
12-09-2026 05:49 AM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
29-08-2026 08:39 PM
