Key Remote Locking Not Working
Hello,
My Central locking with the key is no longer unlocking/locking. The lock button inside of the vehicle will lock/unlock all the doors but i cannot get it to go with the key.
Any suggestions?
So does it unlock any doors with the key? Or are you meaning just the remote button doesn’t work?
I’ve had a few key issues
My little beauty...2009 M59 Peugeot Partner 1.6hdi (90bhp)
Try opening the fob and doing these tests:
1. try pressing the small surface-mount switches directly, without the rubber fob buttons on top of them.
2. If they don't work, try replacing the coin cell.
3. If the switches do work, get a new fob of the same design and put its new rubber buttons into your current fob.
I take it you don't have a spare fob key.
53 1.4i MS MPV RIP
53 1.6 MS Desire RIP
08 C4GP 1.9 VTR+
[-] The following 1 user says Thank You to Gryffindor for this post:
  • patholio
(03-03-2021, 04:17 PM)LukeClark Wrote:  So does it unlock any doors with the key? Or are you meaning just the remote button doesn’t work?
Yes it unlocks if i put the key in the door but not the remote buttons
(03-03-2021, 04:23 PM)Rasputin Wrote:  Try opening the fob and doing these tests:
Hello. Yes i have tried all of the above :Sad and i dont have a spare key to try
Ok, so the small little micro switches on the circuit board don’t work either when you press them when the case is removed? And it’s a brand new battery?
If the small micro switches don’t work I doubt it’ll need a new plastic fob, it sounds like a connection issue. You can buy the micro switches on eBay super cheap. It  may be a soldering joint gone, which ive foubd camera repair places repair cheaply.
[quote pid='132076' dateline='1614792048']
Yes it doesnt work with the case removed either and yes it is a new battery.
i have recently put new micro switches on there and they were working fine. I did just change the radio but cant see that causing an issue?
[/quote]
(03-03-2021, 02:28 PM)TiiTcHY Wrote:  Hello,
Any suggestions?
Is the battery the right way round ?  Big Grin
  • Sol
Any suggestions?
Haha yes it is
Changing the radio is your issue. It is not just a radio - it is part of the car's central control system including the central locking. It is linked via a data bus to the multi function display (LCD panel on top of the dashboard) and in that is chips which are part of the central locking system.
Search this forum for others who have had problems when swapping radios. The problems vary and are not usually to do with the keys, but can be.
53 1.4i MS MPV RIP
08 C4GP 1.9 VTR+
Today 08:32 AM
Today 08:16 AM
03-03-2026 06:17 PM
03-03-2026 05:08 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
Amdro boot jump for sale
Last Post: YTC1
28-02-2026 09:48 PM
Last Post: Muppets on Mars
27-02-2026 01:57 PM
26-02-2026 07:20 PM
