How to add 12v socket near rear speaker
I see that next to the rear right speaker there is a mark where a 12v socket is located (maybe on some trims or by customer request). Is it simple to retrofit? What do I need to get?
I've marked the spot in the pic where it is a clear mark.
Attached Files Thumbnail(s)
If you like gaming visit GameForest
Probaly on the inside of the plastic panel there will be a mark for where the 12 v socket sits and possibly the wiring also.
You may just need a power socket .
Someone else may know better
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
(06-03-2021, 05:35 PM)brodfather11 Wrote:  Probaly on the inside of the plastic panel there will be a mark for where the 12 v socket sits and possibly the wiring also.
yes i can see the mark, just need to cut it, but with what to cut?
and what socket i need?
ebay,amazon has plenty which you can use , You may have to change the terminals on the wiring
Search for 12 volt power socket
I’ve used these on previous cars without issue. Also plan on adding the 12v socket when I get my B9 back on the road.
https://www.ebay.co.uk/itm/164721377016
I want to add it without removing the panel, only make the hole, insert the connector to the socket and then plug the socket into the panel hole.
You could damage the wiring when drilling the hole.
The sensible approach is to take the panel off, if you want the socket. What's the guarantee you can reach the plug through the hole....how long is your finger? :'D
You need the socket fairy to be kind enough to magic the plug so it's sitting exactly behind the bit you drill the hole in, after the cable elves have moved it out of the way first....
Seriously though you need a hole saw the size of the socket body diameter or slightly bigger but not as big as the top lip....they only come in fixed sizes though. Maybe a cone cutter or step drill. First thing would be to buy a used or new factory socket....so that any plug found, will actually just fit. Then measure the diameter of the body so you know the size of hole to drill. Next drill the hole and pray you can reach said plug (and it's not taped to the harness.....out of reach...)
hehe thanks, I'm planning to use a Dremel to make the cut, first I need to find the socket...
Dremel...ouch....lol
You can get a 30mm step drill from b&q for under a tenner mate, honestly it will make a much neater job. Perfect in fact. The steps go up in 1 or 2mm increments and you stop when you reach the right size. I build and alter control panels quite often in my job and these are the dogs bollox.
If I used a Dremel to fit a panel lamp or PLC input button to a machine I'd get fired..... Wink
(07-03-2021, 10:21 AM)Zion Wrote:  Dremel...ouch....lol
I was thinking that the Dremel makes little mess, because I have some small cutter drill (like dentist ones) so the cut is very fine and the mess is minimum
Last Post: rom4ik
Today 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
