Rear door stoppers
Hello
Just wondering if there is a handy way to engage the rear door stoppers.
Manual says they should engage when you shut the van doors but mine wont.
Cheers Tom
Attached Files Thumbnail(s)
Just been out to check ours and they do indeed engage when the door is shut. Perhaps a goodly dose of 3-in-1 oil around the latch on the door may help as they could be seized up or very stiff.
[-] The following 1 user says Thank You to Pedronicus for this post:
  • tommcg
(07-03-2021, 02:59 PM)Pedronicus Wrote:  Just been out to check ours and they do indeed engage when the door is shut.  Perhaps a goodly dose of 3-in-1 oil around the latch on the door may help as they could be seized up or very stiff.
thanks tried a bit of wd40 with no luck
Thanks for confirming the engagement on door closed
Strange thing is its both doors
will try with some oil
Cheers
Just a thought.  Do the arms attached to the van body move freely?
  • tommcg
(07-03-2021, 06:10 PM)Pedronicus Wrote:  Just a thought.  Do the arms attached to the van body move freely?
Yes they pull out no problem
Mine are permanently attached unless I pull the yellow lever. Yours is in the unlocked position. Put the pin in the two round cutouts and swivel the yellow lever till it locks onto that pin. I'll take a pic when I go to work of it locked in.
It doesn't lock on by itself, you have to lock it by swivelling the yellow lever, and then it will stay like that.
It has a spring on the yellow lever, yours must be jammed. Not much between locked and unlocked but enough.
Locked (lined up edge near the van body is unlocked)
  • tommcg
(10-03-2021, 08:13 AM)Zion Wrote:  It has a spring on the yellow lever, yours must be jammed. Not much between locked and unlocked but enough.
Thanks will give that a go.
Pulling the lever towards the van is unlocked so the door can be swung to 180 degrees, insert the pin into the gap, then push the yellow part back towards the door to lock the pin in place.
Oil consumption at 200K miles
Yesterday 12:47 PM
Thermostat Overheating, Radiator Cool
Yesterday 06:24 AM
21-05-2025 06:54 AM
20-05-2025 09:42 AM
» Replies: 54
Last Post: rnamman
19-05-2025 02:03 PM
Last Post: allanr
18-05-2025 05:57 PM
Forum activity
17-05-2025 06:32 AM
Emissions fault.
11-05-2025 06:29 AM
10-05-2025 05:31 PM
Winter Tyres
10-05-2025 02:42 PM
