[Engine] Engine fault, code P1340, jerky accelelaration etc.
Hi guys,
I have a Berlingo 1,6 multispace gasoline 2011 with some 90 000 kilometers under its belt.
It has been regularly serviced and has worked without problems.
Now, I have an issue with the car. It begins when I feel weird jerking acceleration and then the engine fault light comes up.
When I park my car, the ventilator fan runs like crazy. When I check the error codes with a code reader it says P1340 and sometimes also P1340P.
When I erase the errors, the car works like new! But after some time (it can be months of days) it comes up again!
When it appeared first time, a year ago, I erased the error code. All problems disappeared and the car worked ok but I suspected that spark plugs can be the issue. So, I got the spark plugs replaced at the annual service. It was ok for long time but few days ago it came up again! I erased the code and it worked OK for 3 days but today it appeared again. Always the same. Jerky acceleration, then the engine fault light, then after parking the fan stays on.
Is there something i could do by myself before taking it to garage? What could be the problem (spark plugs should be ok)? Anyone experienced similar issue?
Thanks in advance, i am delighted to find this forum Smile
Sorry for my bad english, please ask if you need me to try to explain better.
-Jaakko
This may help! [There was a link here that I have deleted as it may have given bad advice]
(08-03-2021, 05:32 PM)Brixmis7 Wrote:  This may help! http://p1340.enginetroublecode.com/citroen-berlingo
Hi
I just looked through the link provided and could not believe the advice being given  "replace spark plugs every 25 hours of use"
What on earth is that all about?
Geoff
Looks like poor English translation to me, unlike the OP's post above. The whole site has that 'generic' feeling, and contains no clue to its geographical origin, not even by doing a domain name search.
Note that the little graphic of a Berlingo is no such thing - it's just a generic image of a car.
BTW the fault it gives for the code has nothing to do with spark plugs!
53 1.4i MS MPV RIP
53 1.6 MS Desire RIP
08 C4GP 1.9 VTR+
It's a misfire code, could be due to bad coilpack or a fouled spark plug. Worth checking them at least for carbon fouling. The THP engine on the DS3 is well known for it.
Also try disconnecting the MAF when the engine is off then start it and see if it runs ok with it unplugged.
If none of those, maybe something odd like the cam sensor or crank sensor being intermittently bad.
I had a similar occurrence, especially with the fan thing, no idea what the fault codes were as it was under guarantee and went straight to the garage. But the spark plugs were cleaned and eventually changed at the next service.
After talking with the mechanic at the time and the one at the later service, I can only put it down to the low grade/cheap fuel I had been filling up with.
Now a 2019 K9 1.2 petrol.
I agree that website showed nonsense though. Generic piffle.
Thank you all for your input! Need to google if I would be able to find and check coilpack, spark plugs and MAF. I am not really a car expert Big Grin
-J
(12-03-2021, 06:32 PM)jaakkole Wrote:  Thank you all for your input! Need to google if I would be able to find and check coilpack,  spark plugs and MAF. I am not really a car expert Big Grin
-J
As your engine is 1.6 petrol, AFAIK it only relies on a MAP sensor rather than MAF. Of course it could be a newer generation engine that has MAF and I am talking out of my back side.
(08-03-2021, 04:24 PM)jaakkole Wrote:  Hi guys,
-Jaakko
Hi. I've just found this post. I hope it's not to late. Did you manage to find the problem? I have the exact same problem as you. I've got a Citroen C4 Picasso 1.6 VTI. Regards.
Forum activity
Today 05:02 PM
Emissions fault.
11-05-2025 06:29 AM
10-05-2025 05:31 PM
Winter Tyres
10-05-2025 02:42 PM
Start stop on van
Last Post: Rhino2k
09-05-2025 10:28 PM
09-05-2025 09:34 PM
Insurance Shocker !!!
Last Post: Keefus.
09-05-2025 01:45 PM
Part of Dipstick Stuck
Last Post: Nice4dad
09-05-2025 01:25 PM
BSI central locking again
Last Post: stuffe
09-05-2025 09:24 AM
» Replies: 23
steering column bearings
07-05-2025 07:53 PM
