location of blower relay
Hi
I have had an issue with the heated blower, which sort of resolved its self with a replacement resistor, however the blower has completely stopped working now so I thought I would look at the relay.all the images I can find clearly show a relay, when I looked at my fuses etc it appears not to be there. Can someone help point me in the right direction. I have attached some images thanks in advance
Thanks Received: 531 in 479 posts
Thanks Given: 188
23
Ive not got a B9 model but I think others have mentioned its behind the glove box, you need to take it out and its there.
Are we there yet?????
(09-03-2021, 06:58 PM)Tomcat3 Wrote: Ive not got a B9 model but I think others have mentioned its behind the glove box, you need to take it out and its there.
the second photo is from underneath, i cant see it there at all, ill take the glove box out fully, if its there its well hidden. thanks for your reply
Thanks Given: 188
23
Have a look at this thread it should help you locate the relay.
https://www.berlingoforum.com/thread-169...ower+relay
(09-03-2021, 08:11 PM)Tomcat3 Wrote: Have a look at this thread it should help you locate the relay.
Thanks, this is the thread i had seen already and expected a quick fix, i should be able to see that from underneath but i can't, ill remove the rest odf glove box and hope it comes into view
Threads: 20
Thanks Received: 7 in 7 posts
(09-03-2021, 08:33 PM)colkirk Wrote: (09-03-2021, 08:11 PM)Tomcat3 Wrote: Have a look at this thread it should help you locate the relay.
My relay blew a month back when we had the cold weather (not a good time).
I had to take the panel off which is just below the glove box door/flap, you'll see the fuses and a small gap where the relay sits.
It's a knees on the floor outside the car to be able to see it and a headlight.
My only problem is I have 6 screws left and cannot see where they go, but everything is in situ ok.
Multispace B9 2009 1.6HDi
(09-03-2021, 08:49 PM)magoo Wrote: (09-03-2021, 08:33 PM)colkirk Wrote: (09-03-2021, 08:11 PM)Tomcat3 Wrote: Have a look at this thread it should help you locate the relay.
Thanks Magoo, i'll take a look tomorrow and report back
Threads: 63
Thanks Received: 886 in 793 posts
Thanks Given: 145
108
It's bright green, sits in the centre of the space at the bottom when the glove box is out. I'd pull the whole box, access is much better.
(09-03-2021, 09:52 PM)Zion Wrote: It's bright green, sits in the centre of the space at the bottom when the glove box is out. I'd pull the whole box, access is much better.
Found it, I didn't need to remove the glove box, it was tucked right at the back and not easily visible, thanks for all your help
Threads: 63
Thanks Given: 145
108
Yeah I don't know how Citroen expect anyone to work in that rats nest behind the glovebox, especially since the BSI is buried in there on the B9. Its ridiculous. And that apparently "massive" glovebox holds a few mints and a packet of hankies if you're lucky.
Total waste of space due to the internal shape of it.
