[Warning Light] Erratic dash warning lights
Threads: 3
Hi everyone does anyone have a wiring diagram for the instrument cluster warning lights as my dash lights have become erratic lately flickering on and off on switch on and also sometimes driving. Maybe loose connections or bad earth.
Regards
Baz
2005 Peugeot Partner 2.0 hdi quick silver same as M59.
Threads: 75
Thanks Received: 1,308 in 1,140 posts
Thanks Given: 223
164
10-03-2021, 10:44 PM
(This post was last modified: 10-03-2021, 10:48 PM by Sol.)
When you say warning lights flickering do you mean the little icons or the actual orange illumination lighting? There's only 2 plugs I'm sure on the back of the m59 cluster so it will be a dirty connection, worth just cleaning all the plug pins with alcohol and a cotton bud, then make sure the pins come all the way through the plug to the same height. If it's the dash illumination, try pressing and holding the dimmer button on the clocks (opposite one to the trip reset) till they dim fully down, then release and hold it till it goes fully bright again. Engine has to be running for this to work.
Have a look at this post below, might not have the bit you want, diagrams are a bit thin on the M59. I posted some years ago. Haynes would help, their diagrams are good on the Berlingos.
https://www.berlingoforum.com/thread-17165.html
Threads: 3
Hi Zion.
Thanks for the reply it's the icons that are flickering . I will have a go at cleaning the pin pins as you suggest. Will give update soon. Regards Baz.
Threads: 75
Thanks Given: 223
164
Ok, does sound like a bad connection or a dry joint common to the whole display eh.
Threads: 3
Hi
Did what was suggested and cleaned pins. When reconnected switched on and every icon lit up then all went off. I switched off ignition and waited for a few seconds then switched on again. This time all icons that are supposed to come on ie: Battery, oil, engine management, seat belt, air bags, etc all came on and went off as they are supposed to. The only one that never came on was the abs. This happened once before in my old posts. The last time this happened for some unknown reason the light mysteriously came on again and has been working as it should all this time until now. Now it seems I now have the same problem. Regards Baz.
Threads: 75
Thanks Given: 223
164
12-03-2021, 10:25 PM
(This post was last modified: 12-03-2021, 10:29 PM by Sol.)
Could be a blown bulb...they're all just little tiny bulbs like Xmas tree lights. The bulbs are inserted in little twist and lock plastic holders.
Now I was right about the connections, just swap that holder and bulb with another one, if the dead icon moves, it's just a bulb. Go for the simple fix first. Don't over think it.
Threads: 44
Thanks Given: 97
28
In the spare cluster I have, all the small warning lights are actually LEDs soldered to the PCB. May not be the case with all clusters of course.
53 1.4i MS MPV RIP
53 1.6 MS Desire RIP
08 C4GP 1.9 VTR+
Threads: 75
Thanks Given: 223
164
13-03-2021, 08:38 AM
(This post was last modified: 13-03-2021, 08:39 AM by Sol.)
Interesting mate, I'd have thought the M59 had wee bulbs like they use in the heating panel and illumination. SMD LEDs weren't so common 15 years ago.
Threads: 3
Hi my cluster is defo lad's and not bulbs. Led must be ok because it came on after I cleaned the pins. And had been working before.
Threads: 75
Thanks Given: 223
164
13-03-2021, 11:14 AM
(This post was last modified: 13-03-2021, 11:16 AM by Sol.)
Every day's a school day eh. Time to get your meter and soldering iron out then...
Berlingo undertray
Today 06:24 PM
» Replies: 15
Today 08:32 AM
Today 08:16 AM
03-03-2026 06:17 PM
03-03-2026 05:08 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
Amdro boot jump for sale
Last Post: YTC1
28-02-2026 09:48 PM
Last Post: Muppets on Mars
27-02-2026 01:57 PM
