11-03-2021, 01:20 PM
hi all, new on here,but i have an old problem, i have a berlingo2 1.9d wjyb, stop solenoid went bad, ecu smoked with no comms, i swapped 3wire engine cutoff solenoid for a single wire one , s/hand ecu /keyset/ bsi,
now i have comms, glow plugs, lights, horn, indicators, central locking ,tacho, what i don' t have are revs.
i powered the solenoid from reverse switch feed ,starts perfectly but i have no pump advance or ecu control engine fine to 1500 revs ,then smokes ,shakes rattles knocks. only code is the dreaded P1689 with delphi clone,
Also Relay plate control unit,DATA-line;communication faulty.
is there a way to repair this or a work around,i live in hope,mick. ps i tried leaving the old solenoid connected /dis connected no difference.
