  • 1 Vote(s) - 3 Average
Window bolt missing
Hi everyone- noticed I'm missing a window bolt on the rear drivers side door, see pictures.
Any suggestions on where I can get another one, and what it's called to help me search for it?
Thanks!
Attached Files Thumbnail(s)
Citroen Berlingo 2013
1.6 HDi Airdream XTR 90bhp
Second picture
You could probably find the part number from catcar.info
found the parts thanks to an early post - struggling to find where to get the parts from though now..
The cap is P857379, washer P698807
https://peugeotcitroendsparts.com/produc...780p7.html
Cap nut:
https://peugeotcitroendsparts.com/peugeo...ut-857379/
Seal washer:
https://peugeotcitroendsparts.com/peugeo...er-698807/
But none of those parts is a bolt....
[-] The following 2 users say Thank You to Sol for this post:
  • Bubbles, jedmo
Thanks! I'll get them ordered and see what I get Smile
I had one missing and ordered the rubber  / metal cap+ screw from ebay.
I don't think there was a washer, but it didnt look like one was needed.
When I fitted it, the torx screw on the inside of the window is a sod to access, but by removing the rear latch, the window swings out far enough to do it.
I also used soudal fixall crystal sealant to secure the rear of the cap to the outside of the glass, to ensure that it never falls off again.
I also used a bit of thread sealant on the screw, just to make sure.
I see loads of Berlingo Partners with missing window caps, so gluing the damn things on with sealant means they will never fall off again.
[-] The following 1 user says Thank You to Harrythephot for this post:
  • jedmo
(21-03-2021, 08:58 PM)Harrythephot Wrote:  I had one missing and ordered the rubber  / metal cap+ screw from ebay.
thanks - good tips! there some gouges in the latch on the inside of the window- looks like the previous owners had to do this too. Clocked the gouges and thought that this might be fun.......
Parts arrived and coincided with having it booked in for a window tint. The lovely guy fitted the bolt for me whilst he was tinting! Win Smile
Is there defiantly a washer need in addition to the 8573 79? I took my windows out to tint yesterday and I had no washers just cap nut with the rubber cover (see below) I'm doesn't look like I'm the first to remove them just wondering if previous owner lost them.
1.6hdi starting problem
Yesterday 01:38 PM
12-10-2026 02:50 PM
12-10-2026 02:31 PM
12-10-2026 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
