Door Seal
Last question of the night!
Thought as I was buying the window screw/bolt stuff I'd get a new drivers side front door rubber seal as it's a rip in it - not as easy as i thought!
Struggling to find the part number from catcar.info!
And in searching on https://peugeotcitroendsparts.com/ there's loads of types!
How I am meant to know I've the right one? They are quite expensive so I'd like to not get it wrong!
Thanks in advance x
Citroen Berlingo 2013
1.6 HDi Airdream XTR 90bhp
Hi, see here for item 12.....this is for 2012 (my vin) but yours can't be different. Or put your vin in and go to that same section...
http://www.catcar.info/citroen/?lang=en&...I9PQ%3D%3D
  • jedmo
(17-03-2021, 10:19 PM)Zion Wrote:  Hi, see here for item 12.....this is for 2012 (my vin) but yours can't be different. Or put your vin in and go to that same section...
Thanks! It's item 10 I'm after: £134! O_o
May try and find a second hand one....
Sorry yeah 10.... typo. Will a second hand one be better than yours......hmmmm....and come off in one piece...
Not sure about that. But, worth a look I guess.
I think I paid less than £20 for a second hand one a few years back. Tip for getting a good quality used one, go for a used front passenger side door seal, as the seal is the same size and it is likely to have a lot less wear than the driver's side.
Also, go over the seal with a silicone spray before winter.
The seals on my car are still good, and they're original...
(1999 model)
Yesterday 07:24 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
