21-03-2021, 07:58 PM
Hi all.
I'm in the middle of fitting a gates cambelt kit and have a few questions.
Is it best to use sealant along with the waterpump gasket?
Shoud I use locktite on the idler bolts as well as the crank pulley bolt?
This engine has the floating crank sprocket. thinking of setting the belt tension by the 90 degree twist method, starting off with the 2mm gap on the left hand side of the keyway slot. Does this sound ok?
Kind regards,
Mike
Kind regards,
Mike
04 2.0 hdi multispace desire
