2011 1.6 hdi timing belt problem
#21
(25-03-2021, 06:04 PM)gpowens1 Wrote:  in clockwise format camshaft one more inch would be lined
and the crankshaft is 90 degrees past tdc
would this suggest that the crankshaft has possibly been culprit that is out??
If the crank is 90 degrees past TDC the pistons will all be at mid point so no chance of the valves hitting the pistons when you turn the camshaft.
I would turn the camshaft forward until the timing mark is correct. . . then turn the crank backwards 90 degrees to the timing mark.
that was my thinking aswell as it is the least turning and hopefully back to were they were originally at
(25-03-2021, 08:04 PM)gpowens1 Wrote:  that was my thinking aswell as it is the least turning and hopefully back to were they were originally at
How's it going, did you get the timing lined up ok?
hi i forgot to follow it up . i manually rotated the crank and camshaft to line up with holes. locked pump crankshaft and camshaft up and fitted new belt and kit. engine rotated freely. took 10 rotations to get pump to line up with the other 2 even though it isnt required but for piece of mind i kept rotating until the 3 lined. as all lined and engine was rotationg freely i turned the key when all parts put back together and thankfully all was ok. it somehow must have slipped timing i dont know who but it must have at the start.thanks everyone for your help and advice
[-] The following 1 user says Thank You to gpowens1 for this post:
  • jj9
Glad you got it working. Did you turn the crank backwards at first to get things lined up?
yes crank back anticlockwise 90degrees and had to turn camshaft clockwise 1 inch more to line both
  • cancunia
Removing sticker residue
Last Post: ae3
Today 06:49 PM
MyCitroen App
Today 10:22 AM
2009 berlingo 1.6 hdi EGR issues?
Today 06:54 AM
DV6C 9HL injector options
Yesterday 10:18 PM
Advice on Fuel Pump Please
Last Post: magwych
Yesterday 12:18 PM
Eolys low level
Last Post: Teep
Yesterday 09:12 AM
Crank pulley issues 1.4 05 Multispace
Last Post: Van Rouge
Yesterday 06:22 AM
Tyre pressure monitor
14-04-2024 12:00 PM
Resistor cooling fan
Last Post: SteveE
14-04-2024 07:45 AM
Forum "login"
Last Post: Gryffindor
13-04-2024 05:53 PM
